magnet0's avatar
magnet0
Does Netgear WNDR3400v3 support 802.1X / RADIUS / WPA2-Enterprise?
Hi,
Netgear WNDR3400v3
Current Firmware Version: V1.0.1.24_1.0.67
Documentation in this link says it supports WPA2-Enterprise, however the option is not visible in http config page
https://www.downloads.netgear.com/files/GDC/WNDR3400V3/WNDR3400v3_UM_19June2014.pdf
802.11 security WPA-PSK, WPA2-PSK, and WPA/WPA2 Enterprise.
I see a new firmware update but not sure if this has support for wpa2-enterprise
https://kb.netgear.com/000062152/WNDR3400v3-Firmware-Version-1-0-1-32
Please suggest how i can enable 802.1x Wpa2-Enterprise on my router.
Yogesh
    • magnet0's avatar
      magnet0
      I tried "check for updates" in the router http page and it return none however online i see a new FW update, not sure why the routers web page was unable to find a new FW update. i have had issues in the past updating fw and had to revert back to the prev version.
      couldn't find wpa2 enterprise support in change logs for new fw. I'll check again in case i miss something.
      • olympos1625's avatar
        olympos1625
        NETGEAR Employee Retired
        Hi magnet0,
        Good day!
        Welcome to NETGEAR Community!
        First of all, we do apologize for the inconvenience of not getting back to you immediately due to the backlog in the system. Have you checked the Wireless Settings page under wireless security type?
        Please do not hesitate to let me know if you need further assistance.
        Oliver
        Community Team
