tail0r
Feb 22, 2017Follower
Does readyShare support encrypted HFS+ disks?
I'm using NETGEAR R6100 and was wondering if readySHARE supports encrypted HFS+ disks.
I use my portable hard drive to storage files and do Time Machine backups. Since I sometimes need to take my hard drive with me, I encrypted it using macOS's feature.
It's exciting that readySHARE does support Time Machine, but after connected my hard drive to the USB port on R6100 router, I didn't find an option to type passcode for accessing my hard drive.
Hi tail0r,
You can check the link below for the file formats supported by ReadySHARE which includes HFS+ but may not work with the one's with encryption.
http://kb.netgear.com/app/answers/detail/a_id/24059
Dexter
Community Team
1 Reply
- DexterJBNETGEAR Moderator
Hi tail0r,
Dexter
Community Team
