phdgolf's avatar
phdgolf
Does the R6260 support usb printers via the ReadyShare Printer Utility
Good day,   I have a HP Laserjet 6 with a Parallel to USB adaptor that I would like to attach to our R6260 as a shared printer over my home network.  I see that the R6260 supports USB 2.0 storage d...
  • antinode's avatar
    Dec 07, 2019
    > I have a HP Laserjet 6 [...]
       Nice antique (if it stilll works).  Except for its poor network
    support, of course.  (AppleTalk/LocalTalk being pretty tough to find
    anywhere these days.)
    > [...] I see that the R6260 supports USB 2.0 storage devices but I
    > can't find any information that it supports the ReadyShare Printer
    > Utility. [...]
       If it's not in the R6260 User Manual (which seems to be true), then
    I'd say that you're doomed on the USB front.
       You might see if you can find a bargain on an obsolete print server,
    which could provide an Ethernet-to-parallel-port path.  The printer
    User's Manual mentions the (also obsolete) JetDirect EX, J2591A, but
    some newer (more common?) models might also work.  Ebay?
