kmccarthy83's avatar
Sep 10, 2018
Does this router support MoCA?
I have not had much luck with 2 differnet extenders, I have tried moving my modem/router as well with no luck. While shopping at Best Buy the other day I came across a moCA kit (see below). I haven't...
  • antinode's avatar
    Sep 10, 2018
    > I have not had much luck with 2 differnet extenders, [...]
       Not much meat on that bone.  What's the actual problem which you are
    trying to solve?
    > [...] I came across a moCA kit (see below). [...]
       Ok.
    > [...] where I work we use moca networks and I know that we do require
    > routers or combo units (modem/router) to support moca. [...]
       "require" is a dangerous word to use in such a situation.  As usual,
    many things are possible.
    > [...] So I am trying to find out if this router has moca support?
       Is your "this router" one of these?:
    >  Model: R6400v2|AC1750 Smart WiFi Router-802.11ac Dual Band Gigabit
       If your router doesn't have a co-axial cable connector, then it
    doesn't support MoCA.  But that's why those MoCA adapters are sold in
    kits of two.
          https://www.actiontec.com/products/home-networking/ecb6200/
       All that MoCA hardware does is let you use an existing co-ax cable
    instead of running a simple Ethernet cable between the same points.
    Other than the MoCA adapters, you don't need any special devices.
       You can probably get a device (like a router, or a wireless access
    point) which has a built-in MoCA adapter, and save the cost of an
    external MoCA adapter at its location, but all you need to use a
    non-MoCA device in a MoCA network is another MoCA adapter.
