ADAMT840
May 03, 2022Aspirant
DOS ATK THAT SEEMS TO BE CAUSING MY PC TO DISCONNECT FROM THE INTERNET
For the last couple weeks ive been getting disconnection while using my pc from games and streams, ive been checking event viewing and trying fixes for some errors i noticed there i also had microsof...
ADAMT840
May 05, 2022Aspirant
this time though it said Winnuke atk instead of ack scan
DexterJB
May 12, 2022NETGEAR Moderator
Hi @ADAMT840, if you haven't yet, we recommend contacting our support team. You can always reach our support team via the link below if you need any technical assistance with your NETGEAR device.
https://www.netgear.com/home/contact-us/default.aspx
You can also call the number below.
1-888-NETGEAR (1-888-6384327)
Dexter
NETGEAR Team
