LeoCadaver
Dec 30, 2020Follower
Double NAT Type Xbox One
I have an AC1200 WiFi Cable Modem Router and I can’t make my NAT type open on my Xbox. I’ve already tried opening my UPnP, but that didn’t do anything. Any other suggestions? Please and thank you
- No1MportntLuminary
Log into your router and set your NAT filtering radio button to open.
you can also try setting the xbox as the default dmz if opening nat doesn't work for you.
https://kb.netgear.com/1118/How-do-I-configure-a-device-to-be-in-the-DMZ-on-my-NETGEAR-router
