RileyStow
Apr 15, 2022Aspirant
download a update
I have tried every password that I have used and can't get thru to update the new download..... Do I have to go to a reset nd start over?
if you can't get logged in to the router, yes, you'll need to factory reset and setup from scratch using a web browser and PC.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
- RileyStowAspirant
I want to thank you for your info......I was able to start over and got the two updates but I was to log in after that and with the new login password it would not accept me. So interesting but the downloads got in so I wait till I have to login again. J
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
