victorsoyvictor
Jun 06, 2021Aspirant
Download slower than upload
Firmware Version V1.0.4.46_10.0.93 Macbook Pro M1 2020 iPad Pro 2019 iPhone 12 Pro Max Using 5ghz and keeping an eye in neighbourhood channels. Speedtest by Ookla Server: Ada...
Jun 07, 2021Guru - Experienced User
What modem/gatway are you using?
Did you try other servers? speedtest doesn't always choose the best server.
did you try factory resetting and reinstalling the router? Make sure to test it in default configuration. its a bit of an older router so make sure during the install to leave qos, access controls, parental controls, and traffic monitoring all disabled.
