victorsoyvictor
Jun 06, 2021Aspirant
Download slower than upload
Firmware Version V1.0.4.46_10.0.93 Macbook Pro M1 2020 iPad Pro 2019 iPhone 12 Pro Max Using 5ghz and keeping an eye in neighbourhood channels. Speedtest by Ookla Server: Ada...
victorsoyvictor
Jun 07, 2021Aspirant
Hi,
I’m using ZTE F680, which also does something similar with WIFI connection speed (~120down/~400up)
It is driving me crazy, I don’t touch anything in the Netgear, only changed IP and disabled DHCP from default (not even the default pass lol )
Jun 07, 2021Guru - Experienced User
So the device the netgear is connected to (and getting its signal from) has the same issue?
That'd seem to imply the ZTE was the bottleneck and creating the issue since the netgear has to connect through the zte.
- victorsoyvictorJun 07, 2021AspirantIt is wired to ZTE, cat 5e. I have 600/600 with cable.
- plemansJun 07, 2021Guru - Experienced User
If you're testing the speeds on the zte and its only getting 120mbps down, why do you expect the netgear to get faster speeds?
Understood that you have cat 5e and 600/600 service. But if you're gateway isn't putting out 600mbps service, then the netgear isn't going to get it.
What speeds do you get from the zte hardwired into it?
- victorsoyvictorJun 07, 2021AspirantZTE gives 600/600 cable
Netgear gives 600/600 cable
Problem is WIFI, I assume NETGEAR’S antenna has nothing to do with ZTE’s one, I was just noting the coincidence. Is like download Antennas are limited somehow… I have tested channels and the rest by default.
