mark9r
Feb 05, 2017Aspirant
download speed
My router speed is 1190 kbs while my tethered internet speed is 70Mps. I have restarted, reset, unplugged but it doesn't seem to work. I cannot connect my wireless services like Roku and I suspect ...
- Feb 11, 2017Elaine. It turned out to be the IP address. I have no idea how it changed from one day to the next but when I corrected it, the connection was reestablished with all devices. Thanks very much for your help.
mark9r
Feb 06, 2017Aspirant
Hi Elaine. Thanks for your help. It's an N300. WNR2000v5. I've reset it by pushing the concealed button - if that's the same as "factory" reset. Connected is a Roku streaming service and Kindle. On each device it shows the router as available w excellent strength. I sign in with the correct router password but I get unable to connect error messages. The Roku settings actually say I'm connected but when I try to access Amazon Prime, Showtime, Netflix I am not able due to no connection to the internet. I suspect there is something simple I'm missing. I just don't know what.
ElaineM
Feb 07, 2017NETGEAR Employee Retired
How far is the router from these devices?
Is there any device such as smartphone that can get online on the same exact location where the Roku is?
What's the exact error message do you get?
It's possible that your Roku is not getting a valid IP address from the router to get Internet access.
Is there a device that has internet access through the router?
