mboudrie
Sep 20, 2018Aspirant
droid cell phone will not connect to wifi
I have had the Netgear adapter & cell phone for over 2 yrs with no problems with the WiFi connection between the two devices untill last month. My cell phone connects to the Netgear & immediately di...
- Sep 20, 2018
You could temporarily disable the WiFi security and try it. If successful, recheck the password key.
TaterSalid
Sep 20, 2018Virtuoso
- mboudrieSep 20, 2018Aspirant
I have not security on my Netgear adapter. I previously had viewed what I thought was all possible security measures on my phone. I took another look at my phone & under other than security found it was blocking Netgear. So block off, WiFi on phone is connecting & staying connected. Thanks for your help. Pointing me again at possible security issues made me look again & find my problem.
- TaterSalidSep 20, 2018Virtuoso
You are welcome.
