mboudrie's avatar
mboudrie
droid cell phone will not connect to wifi
 I have had the Netgear adapter & cell phone for over 2 yrs with no problems with the WiFi connection between the two devices untill last month. My cell phone connects to the Netgear & immediately di...
  • TaterSalid's avatar
    Sep 20, 2018
    You could temporarily disable the WiFi security and try it. If successful, recheck the password key.
