N300GK
Jul 22, 2016Initiate
DUAL VOLTAGE ON N300 WIFI ROUTER
I BOUGHT THE N300 ROUTER IN THE US, DOES ANYONE KNOW IF THEY ARE DUAL VOLTAGE AND I CAN TAKE IT TO EUROPE AND USE IT? THANKS
- Jul 22, 2016
You should verify it yourself by looking at the power adapter. If it is says the input voltage is 110V only, then it's US-only. If it says 110V-240V, then it's universal.
VE6CGX
Jul 22, 2016Master
It is not dual voltage any more. Usually universal voltage type which will work with voltages from 110V to 240V with frequncy of either 50 or 60Hz. Most routers are like this. If you got the router locally it'll have different AC plug or plug adapter in the package.
