N300GK
Jul 22, 2016Initiate
DUAL VOLTAGE ON N300 WIFI ROUTER
I BOUGHT THE N300 ROUTER IN THE US, DOES ANYONE KNOW IF THEY ARE DUAL VOLTAGE AND I CAN TAKE IT TO EUROPE AND USE IT? THANKS
- Jul 22, 2016
You should verify it yourself by looking at the power adapter. If it is says the input voltage is 110V only, then it's US-only. If it says 110V-240V, then it's universal.
N300GK
Jul 23, 2016Initiate
THANKS FIOR EVERYONE'S RESPONSES, THE ADAPTER STATES 100-240V, SO IT IS UNIVERSAL
