stepheat
Mar 18, 2020Aspirant
Duplicate IP Address
I just got this router yesterday and setup was easy. However, when I look at the Advanced tab I see duplicate IP addresses: The first is my Samsumg phone (checked the MAC address) and the second is ...
- Mar 20, 2020
Okay...I didn't change the DHCP pool range but I did give my printer a static IP 0f .100. I have seven devices total and they all get assigned an IP below .010 so I should be good. Thanks for your help.
antinode
Mar 18, 2020Guru
> [...] when I look at the Advanced tab I see duplicate IP addresses:
_Where_ are you looking? An "Attached Devices" report, or some other
thing/place? What's there other than the duplicate-address devices?
Does the problem persist after shutting down all the devices and
restarting them? Are all the client devices configured to use DHCP?
