acaste4246
Apr 02, 2017Aspirant
E-mailing logs
I am trying to set up my router so it will e-mail me the logs everytime they are full. I am compleying all of the fields and clicking "apply" and its mot saving any of the information. The screen refr...
- Apr 05, 2017
Hi acaste4246,
1. What is the model number and firmware version of the router?
2. You can try the steps below.
a. Log in to your Gmail then go to Settings.
b. Click on Accounts and Import then click Other Google Account settings.
c. Go to Security Check-up.
d. Click on Disable access on less secure apps.
e. Select the radio button to turn ON Access to less secure apps.
f. To test if it will send the logs via email, go to the router logs option on the router's GUI then click on Send Log.
g. You should now receive the router logs.Regards,
Dexter
Community Team
acaste4246
Apr 05, 2017Aspirant
Hello DexterJB...
Thank you for the reply.
1) Nighthawk R7000
Firmware Version
V1.0.7.10_1.2.3
I followed the steps you outlined and clicked on Security Check Up. I am prompted through a series of steps:
1) Recovery Information
2) Connected devices
3) Check you account permissions
At this point there is no radio button as you described to turn ON Access to less secure apps.
Do you have any other suggestions for setting up the e-mail?
Thank you,
Anthony
DexterJB
Apr 11, 2017NETGEAR Moderator
Hi acaste4246,
You can check the link below for the steps.
https://support.google.com/accounts/answer/6010255?hl=en
Dexter
Community Team
- DexterJBApr 17, 2017NETGEAR Moderator
Hi acaste4246,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
