SenperFiAspirantFeb 21, 2024Edit name in community log in Good morning How do I edit my log in name that is associated with community log in Regards Pete
FURRYe38Guru - Experienced UserFeb 21, 2024You'll need to get ahold of a forum moderator for that. I presume you meant SemperFi? KevinLiT
SenperFiAspirant to FURRYe38Feb 21, 2024Thanks for the response and I will attempt to get hold of a moderator You are correct SemperFi typed it in wrong PeteFURRYe38Guru - Experienced User to SenperFiFeb 21, 2024👍
