ranger7's avatar
ranger7
Enable PC wireless adapter onW7
AC6100/Model No R6250   How do I enable the PC (Windows 7) wireless adapter?
  • DexterJB's avatar
    DexterJB
    Oct 11, 2017
    Hi ranger7,
    1. Are you trying to connect your wireless Windows 7 computer to the wireless network?
    2. Is it a laptop with a built in wireless adapter or a desktop with an external wireless USB adapter?
    3. If it is a laptop, which mostly has a built in wireless adapter, you may consult the device user manual.
    4. If it is a the latter, please make sure that the drivers for the wireless adapter is installed.
    Dexter
    Community Team
