Hacheta
Mar 08, 2018Tutor
Enable Remote Access Fails - "Incorrect request format, try again."
I no longer can login to my router using genie app remotely , the remote access is not Turing on anymore and it gives me “Enable Remote Access Fails - "Incorrect request format, try again." I updated ...
- Mar 09, 2018
Hacheta wrote:
I no longer can login to my router using genie app remotelyIs that the Android genie or the iThing genie? It might make a difference.
Hacheta wrote:
I updated the router to the latest software.Did you reset the router to factory settings after the firmware flash?
New firmware sometimes introduces changes that are not compatible with the old configuration.
So while it isn't guaranteed to fix problems a factory reset is the first thing to try if you have issues with new firmware.If you do reset it, remember to enable remote access again. Indeed, check that it is still enabled before you reset. Maybe the firmware flash turned it off some how.
michaelkenward
Mar 09, 2018Guru - Experienced User
