darkmet
Sep 12, 2021Follower
enable telnet on dgn2200 V1.0.0.60_7.0.57
hi all, i can't enable telnet with any telnetenable.exe or telnetenable2.exe etc... i send this: telnetEnable.exe X.X.X.X XXXXXXXXXXXX admin password (pw is from web access). Also with old Ge...
michaelkenward
Sep 13, 2021Guru - Experienced User
darkmet wrote:
With previous firmware all was working, but now with V1.0.0.60_7.0.57 i can't access any more.
Netgear is removing the telnet backdoor from routers. But I am surprised that they are bothering with something as ancient as the decade old DGN2200. That they have put out new firmware as recently as 2000 is a bit of en eye opener.
You don't say why you want to telnet into this device. If it is a one-off move, you can revert to older firmware, do what you want, and then reapply the newer firmware.
The DGN2200 is a DSL modem/router, soyou might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
DSL Modems & Routers
