hafizullah
Jul 06, 2018Aspirant
enable telnet on R6300v2
Model R6300v2, stock firmware V1.0.4.24_10.0.87. OS: Win7/64 on my desktop. I'm trying to get telnet access to the router. I have tried the telnetenable, telnetenable2, and telnetgear utili...
- Jul 06, 2018
For others:
http://www.antinode.info/nte/index.html
Download & extract nte-05/nte-05_win.zip
Run it from the Windows CLI.
antinode
Jul 06, 2018Guru
> [...] the link to nte that you provided does not appear to work.
Which "the link"? Re: "does not appear to work", see "tried" + "to
no avail", above.
hafizullah
Apologies. The link wasn't. However, I did find your exefile and ran it, with this result:
debug: 0xffffffff .
MAC0: >04A1512574CA<.
MAC1: >04A1512574CA<.
user: >admin<.
pass: >Fl1bberdeg1bbet<.
getaddrinfo():
ai_family = 2, ai_socktype = 0, ai_protocol = 17
ai_addrlen = 16, ai_addr->sa_family = 2.
ai_flags = 0x00000004.
ai_addr->sa_data[ 2: 5] = 10.0.0.1
dns_resolve() sts = 0.
sock = 128, FD_SETSIZE = 64,
FD_ISSET( sock, &fds_rec) = 1.
pre-select(1). sock = 128.
pre-recvfrom(). sock = 128.
recvfrom() bc = 3.
s_addr: 0100000a .
recvfrom() addr: 10.0.0.1
41 43 4b ACK
nte: Received ACK message. Telnet access should be enabled.
select(1) sts = 0.
AND THAT GOT ME IN. THANK YOU! Have the # prompt and "nvram show" tells me what I need.
- hafizullahJul 06, 2018Aspirant
For others:
Run it from the Windows CLI.- antinodeJul 06, 2018Guru
> Apologies. The link wasn't. [...]
I'll bite. "The link wasn't" _what_?
You might want to change that.
> For others:
Was there any actual problem with the original link provided here, or
the link on that page to the Windows executable kit?
As the web page says (and I thought that the README made sufficiently
clear), "[...] and has a command-line interface". So, yes, on Windows,
you'd want to use a Command Prompt or PowerShell window to run it.
> Solved! [...]
It's always gratifying to see credit given where it's due.- hafizullahJul 08, 2018Aspirant
My eyes aren't good, so I could not find the link to net.exe in the page you referenced in your answer here.
However, I did a query and found your page describing it and links to the makefiles & executables. Thank you for your work.
Did. Also changed the admin login name to something random, which is one of the things I wanted to do in the first place.
I am trying to break into my wnr2000v3, but the connection is refused. antinode, will you look at a nte.exe report in PM, or should I open a new topic in that unit's forum?
