crestan
Jul 18, 2021Follower
Enable telnet WNDR4300 in Windows 10
Old Telnet activation methods don't work in Windows 10! Please, give verified and step-by-step recommendations for Windows 10, if anyone succeeded. Thank you very much
antinode
Jul 18, 2021Guru
> Model: WNDR4300|N750 Wireless Dual Band Gigabit Router
Firmware version?
_Which_ "Old Telnet activation methods"?
"not work" is not a useful problem description. It does not say what
you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
What led you to believe that Windows 10 is related to this particular
(unspecified) "don't work"? I'm unaware of any fundamental problems
with this functionality related to Windows 10. Around here ("Version
20H2 OS Build 19042.985", D7000[v1], V1.0.1.78_1.0.1), for example:
C:\xxx\nte-05_src>nte n=dsl m=B0:7F:B9:xx:xx:xx u=admin p=password
nte: Received ACK message. Telnet access should be enabled.
Whether anything works on your device with your firmware version is
unknown to me. On the R7000, for example:
https://community.netgear.com/t5/x/x/m-p/1786837
You mean the way you described the failure(s)?
