eldiener's avatar
Jul 24, 2016
Enabling 5g router band for wndr3800
How do I enable the 5g band of my router so that it shows up among the networks to which I can connect ?
  • TheEther's avatar
    Jul 24, 2016
    Log into your router and go to Basic > Wireless.  Make sure Enable SSID Broadcast is checked.  If you have never set up the 5 GHz band before, then set the SSID name and password.  It's strongly recommended to use WPA2 security.
    Go to Advanced > Advanced Setup > Wireless Settings and make sure Enable Wireless Router Radio is checked.
    Finally, any devices attempting to connect to the router at 5 GHz must, of course, support operation at 5 GHz.  Otherwise, the 5 GHz band won't appear on those devices.
