Peobody
Jan 20, 2022Guide
Enabling Downstream QoS crashes router
I have just finished doing a factory reset along with a firmware update to V1.0.4.122_10.0.95. I have been working through reconfiguration and the router is routinely crashing after applying changes...
michaelkenward
Jan 21, 2022Guru - Experienced User
Peobody wrote:
One setting crash that is reproducible is when trying to enable Downstream QoS. I see an error message that says something to the affect of 'No data sent'. A router reboot is then required. Is this crash a known issue? Is it fixable?
QoS requires processing effort and is famously good at bringing a router to its knees. Disabling QoS is the first suggestion when someone asks about router problems.
Given that the R6400 is not of the most powerful routers around, it isn't surprising that it has a problem with QoS.
You don't say how fast your Internet connection is, but the general advice is that with anything above 300 Mbps, some say even 200 Mbps, you should disable QoS. At those speeds it isn't necessary.
- PeobodyJan 21, 2022GuideI have a 50 Mbps service and have had QoS enabled for some time. The crash is new to this firmware. Since I am reconfiguring from scratch I wanted to make certain that it was a router/firmware problem and not something in my configuration.
- plemansJan 21, 2022Guru - Experienced User
Peobody wrote:
Since I am reconfiguring from scratch I wanted to make certain that it was a router/firmware problem and not something in my configuration.tough to say 100% if its a bug or just an issue with your specific device. all you can do is try the factory reset and reinstall. If it crops back up after the reset/reinstall, then try downgrading a version.
- PeobodyJan 28, 2022Guide
This installation followed a factory reset. I don't care to go through that again and shouldn't have to. Besides, I am soooo tired of having to downgrade firmwares. I had to do it after 1.0.4.118 and again after .120, returning to 1.0.4.106 both times. It's disconcerting to think that a firmware four versions old remains the most recent fully functioning version for this device. Everything else appears to be working as it should so I will live without QoS.
