ICT-Amateur's avatar
ICT-Amateur
Follower
Nov 26, 2020
Enquires about the BootUp Time for NetGear Router Model R6260
Hello,
To those guys/gals that have NetGear Router R6260 with Home Broadband Service. I sincerely require your help in the following:
1) Possible to let me know the BootUp time (in Sec) for your Netgear Router model R6260??
You can calculate the difference in timing by powering up your router till it is online and then login to the Netgear Router User Interface using web browser and go to Advanced -> Administration -> Logs. You can calculate the difference in timing by using (Time synchronized with NTP server) - (Time when Initialized) = Time (Sec).
My issue is that my router's bootup time has shorten as compare to last time and I am not sure if this is normal. Therefore require your help Please.
Please state your firmware version and the time (in sec).
Thank You So Much for your help in advance.
No RepliesBe the first to reply
