codibelcalm
Sep 23, 2025Tutor
EOS - need new device for my network
Hello, I got an email from Netgear notifying me that my router R6220- AC1200 has reached end of service and is no longer supported. The recommendation was to upgrade to Nighthawk WiFi 7 Router R...
- Sep 23, 2025
I would wait until black Friday sales or cyber-Monday or even end of year after Christmas, then you can get what you want hopefully on sale. Just because something is EOL, doesn't mean you have to upgrade right away, especially if you are not having issues.
codibelcalm
Sep 24, 2025Tutor
Hi, and thank you for the recommendation! The only outlet I know of is Amazon. Maybe newegg? I'm definitely willing to go with a refurbished device.
Thanks again!
JWS9518
Sep 25, 2025Luminary
I personally am leery at buying a used/renewed electronic device as you never know what you are going to get. You may get something that had no issues and was returned, or you may get the opposite, but to each his own.
- plemansSep 25, 2025Guru - Experienced User
I've bought quite a few renewed/refurb devices. The nice thing about going with amazon is usually there's an option to buy a warranty, and if there's issues, you can always return it in their return window. Its not like a car where someone was abusing it. Usually routers work or they don't. there doesn't tend to be much in between. So if you get one that works, awesome.
- JWS9518Sep 25, 2025Luminary
Yes, and you could be correct they could be fine, and they make work alright for a while, but heat and use is the enemy of electronic devices which is why I stay away from used devices, because I don't know how long they have been used and abused and renewed usually doesn't mean much when it comes to electronic devices, other than being cleaned a bit. For me, I am just not comfortable taking that chance.
And thats where the warrany comes in IF you think its a gamble. $12 for a 4 year warranty for a $70 router. So a total of $82. Still pretty cheap and 4 years if something goes wrong. But feel free to buy it new for $190. I think I'd gamble on that one because in 4 years, it'll probably be time for an upgradeto either a Wifi 8 device or last gens wifi 7 device
- codibelcalmSep 25, 2025Tutor
Hi, I'm generally leery in that way, too. It's a crap shoot. With my luck, I'll get the 1-in-a-1000 dud. I'm not the savviest of techies. Wouldn't want to mess with all the troubleshooting. I'm too busy protesting. Many thanks.
Well, I hope whatever device you decide to get it works well for you. A new wi-fi 7 capable device will definitely be a difference for you.
