codibelcalm
Sep 23, 2025Tutor
EOS - need new device for my network
Hello, I got an email from Netgear notifying me that my router R6220- AC1200 has reached end of service and is no longer supported. The recommendation was to upgrade to Nighthawk WiFi 7 Router R...
- Sep 23, 2025
I would wait until black Friday sales or cyber-Monday or even end of year after Christmas, then you can get what you want hopefully on sale. Just because something is EOL, doesn't mean you have to upgrade right away, especially if you are not having issues.
Sep 25, 2025Guru - Experienced User
I've bought quite a few renewed/refurb devices. The nice thing about going with amazon is usually there's an option to buy a warranty, and if there's issues, you can always return it in their return window. Its not like a car where someone was abusing it. Usually routers work or they don't. there doesn't tend to be much in between. So if you get one that works, awesome.
JWS9518
Sep 25, 2025Luminary
Yes, and you could be correct they could be fine, and they make work alright for a while, but heat and use is the enemy of electronic devices which is why I stay away from used devices, because I don't know how long they have been used and abused and renewed usually doesn't mean much when it comes to electronic devices, other than being cleaned a bit. For me, I am just not comfortable taking that chance.
