gjb50
Dec 18, 2021Aspirant
ERROR 403
What the hell is going on with this model. I have three customers with the exact same issue. Netgear needs to get their head out of their a#$. None of the solutions I have found work other than bu...
michaelkenward
Dec 19, 2021Guru - Experienced User
Which model? AC1000, like AC1200, is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
The R6080 in your footer is pretty well Netgear's bottom of the range router.
Quite what possessed Netgear to release devices with 100 Mbps Ethernet ports in 2017 is beyond me. Gigabit has been LAN standard on most routers for a decade or more. Since then Internet speeds have crept up and 100 Mbps is slower than many ISPs deliver.
Still, the thing should work, albeit slowly.
Solved: R6080/ac1000 router. Bugs !!! - NETGEAR Communities
Spoiler
The "tagged" title is misleading.
gjb50
Dec 19, 2021Aspirant
Top of the line or bottom is not the issue. Here is the definition of error 403 if you are uncertain:
The HTTP 403 is an HTTP status code meaning access to the requested resource is forbidden. The server understood the request, but will not fulfill it.
With the router being the server.
Same results with different browsers....
For those of you who have been setting up Netgear remember the good old days before the Wizard, when it only took half the time.
Bye Bye Netgear, no more referals from me.
Check out the solution in the above reply.
No need to reply
