sandokanfirst
Mar 31, 2021Guide
Error DNS_PROBE_FINISHED_NXDOMAIN after update to V1.0.1.70_1.0.44 of firmware
Hi all, Ever since I have updated my AC1750 R6400 router every other site I try to open gives a DNS_PROBE_FINISHED_NXDOMAIN error. If I refresh (F5), the website in question usually opens. It's a bi...
Mar 31, 2021Guru - Experienced User
Whenever I run into an issue after a firmware update, one of the first steps i try is a factory reset with a new install (not using a backup configuration)
have you tried this?
sandokanfirst
Mar 31, 2021Guide
No, I haven't done that yet. I always dread the moment I have to reconfigure the router by hand, but I think you're right that is the wise thing to do. I will try that, thanks, plemans !
