sandokanfirst
Mar 31, 2021Guide
Error DNS_PROBE_FINISHED_NXDOMAIN after update to V1.0.1.70_1.0.44 of firmware
Hi all, Ever since I have updated my AC1750 R6400 router every other site I try to open gives a DNS_PROBE_FINISHED_NXDOMAIN error. If I refresh (F5), the website in question usually opens. It's a bi...
sandokanfirst
Mar 31, 2021Guide
Unfortunately, after a factory reset the issue persists. It's fickle. Sometimes websites load immediately, but the next I get either a DNS_PROBE_FINISHED_NXDOMAIN or
ERR_NAME_NOT_RESOLVED. Is there anything else I can do?
Mar 31, 2021Guru - Experienced User
What modem do you have it connected to?
- sandokanfirstMar 31, 2021Guide
It's (I think just locally) known as an Experia box v10A (which is an Arcadyan), the obligatory modem/router for my provider. The Netgear has a wired connection to it (and my computer has a wired connection to the Netgear router).
- plemansMar 31, 2021Guru - Experienced User
Thats a modem router combo device.
It puts you in a double nat.
What is Double NAT? | Answer | NETGEAR Support
do you have the Experia in modem only/passthrough mode?
or the netgears IP address in the experia's dmz?
Or the netgear in access point mode?
The thing is that the Experia doesn't have an passthru only mode or a DMZ. Well, it probably has, but my provider has probably hidden it. But I think that there is not a real problem as the R6400 gets a fixed IP from the Experia as you can see below. Anyway, this has worked well for the past years. ;)
