dawulv's avatar
dawulv
Tutor
Aug 13, 2018
Ethernet Connection good but WiFi not working
Hi ladies and gents,   I've got a Netgear R6400 router that is about a year or so old (maybe 2). About 2 hours ago the internet went out and I thought it may be an issue with my provider. Well, a...
  • dawulv's avatar
    dawulv
    Aug 13, 2018
    I found the issue quickly upon reading the manual. It was a cat25 issue...
    A bit of back story. Just after the internet went down, I observed my wife's cat walk from behind the TV. After finding the issue this is my determination...
    Cat25 issue: My wife's 25lbs cat stepped on the router's 'wifi on/off' button and turned the wifi off. I held the wifi button and its now working. Thanks for the help!
