dawulv
Aug 13, 2018Tutor
Ethernet Connection good but WiFi not working
Hi ladies and gents,
I've got a Netgear R6400 router that is about a year or so old (maybe 2). About 2 hours ago the internet went out and I thought it may be an issue with my provider. Well, a...
- Aug 13, 2018
I found the issue quickly upon reading the manual. It was a cat25 issue...
A bit of back story. Just after the internet went down, I observed my wife's cat walk from behind the TV. After finding the issue this is my determination...
Cat25 issue: My wife's 25lbs cat stepped on the router's 'wifi on/off' button and turned the wifi off. I held the wifi button and its now working. Thanks for the help!
antinode
Aug 13, 2018Guru
> I believe it's a V1 since the model number literally only says R6400,
Yup. Netgear adds a version suffix only when "v2" appears.
> The other LEDs do not indicate anything. The 2.5g, 5g, wifi { ((.)) },
> are all unlit.
"Is there any point to which you would wish to draw my attention?"
"To the curious incident of the dog in the night-time."
"The dog did nothing in the night-time."
"That was the curious incident," remarked Sherlock Holmes.
"unlit" _does_ indicate _something_.
> [...] the only steps I've taken so far are unplugging both the router
> and modem and letting them reset then plugging them back in.
The (unspecified) modem is not involved in this problem. The router
may retain a radio-disabled/enabled status through a simple restart.
There are ways to disable the wireless-network radios in the
management web site interface, but those are much harder to change
accidentally compared with the "WiFi On/Off button with LED". Look for
"Control the Wireless Radios" in the User Manual.
dawulv
Aug 13, 2018Tutor
