HappyGamer211's avatar
Aug 28, 2023
Ethernet drops out, but wifi is fine. R6260
Router: R6260 Firmware Version: V1.1.0.88_1.0.1 PC OS: Duel boot (Windows 10 & Linux Arch)   For a few years now using Ethernet has caused my network to crash. However the connection seems to wor...
  • HappyGamer211's avatar
    HappyGamer211
    Aug 31, 2023
    FOUND MY SOLUTION. So I tested my connection and the router would at points cut out my Ethernet cable connection. The NIC port was the problem and is starting to go faulty and replacing it with a USB 3.0 to Ethernet fixed it.
