smintz
Dec 25, 2015Aspirant
every day my ex6200 disappears
I have an R6300v2 (terrible) router and an A6200 adaptor wint an EX6200 extender in between. whenever it feels like it, the EX6200 drops out and leaves the router as my connection. I cannot find t...
- Jan 06, 2016Found problem. After 4 cox service calls. Not one did correct install. Finally got someone who knew how to configure. All other service people had wrong band and channel and directed traffic to the 2.4 band. Now connected to router. Do not even need extender. Not wonderful but getting about 240Mbps down instead of 40
DexterJB
Dec 26, 2015NETGEAR Moderator
Hi smintz,
1. Does the issue happen to all wireless devices?
2. How far is the device (using the A6200) from the EX6200?
3. Is the device (using A6200) getting a good signal from the EX6200?
4. What is the operating system of the device experiencing the issue with the NETGEAR Genie?
5. Have you tried using the NETGEAR Genie with another device (another computer, smartphone,tablet)?
Dexter
Community Team
- smintzJan 03, 2016Aspirant
No, Phones keep connection, but speed is unknown. Printer requires reboot every time.
EX6200 2 rooms from R6300v2(router) 1 room from PC
Yes
Win105. Have you tried using the NETGEAR Genie with another device (another computer, smartphone,tablet)?
Netgear genie shows connected to EX6200, but speed ranges from 40Mbps to 140(seldom)
Every day I require either a manual disconnect when it shows as "connected" to get back a passable connectoion, or "connect" due to no connection.
My old dlink router Never lost a connection, the netgears are continuously dropping off
- DexterJBJan 03, 2016NETGEAR Moderator
Hi smintz,
1. Have you tried re-installing the drivers for the A6200 adapter?
2. Did you upgrade the computer from a previous version of Windows to Windows 10?
3. Does the disconnection issue occur on both the 2.4GHz and 5GHz band?
Dexter
Community Team
