seagrace
Sep 09, 2023Aspirant
Every website now says my connection isn't secure after hard restart
I have a R6400v2 — AC1750 router and Netgear modem. My Sonos started getting jagged and not connecting. I did a hard restart on everything including unplugging, which usually works. It didn't fix a...
- Sep 12, 2023
Thank you for your reply. I have a Netgear modem and Netgear router.
Somehow the problem fixed itself. Perhaps if I ignored it that may have happened.
Sometimes later at night Comcast does things and email and connections get screwy. Apparently the connection reset and all my websites loaded as normal.
seagrace
Sep 12, 2023Aspirant
michaelkenward
Sep 13, 2023Guru - Experienced User
If you need help in future, tell people what that modem is. Netgear has made many over the years. They aren't all the same.
