sam340190
Nov 20, 2021Aspirant
ex3700 tmobil hotspot connectivity issues
Hi there, I am having issues connecting a ex3700 wifi extender to an Inseego 5ghotspot from tmobil. The process I have tried is as follows. 1. reset extender. 2. find the extender network, netgea...
michaelkenward
Nov 21, 2021Guru - Experienced User
sam340190 wrote:
Hi there,
While many questions are generic – they apply to different devices regardless of their model number – in this case there are two devices involved, neither of which belongs in the category covered in this section General WiFi Routers (Non-Nighthawk and Non-Orbi).
The ex3700 wifi extender. You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
WiFi Range Extenders & Nighthawk Mesh - NETGEAR Communities
As these things depend a lot on the device you plan to "extend", you may get better help over where they talk about this Inseego 5ghotspot. A quick search shows little sign that it is a router. But that label makes it impossible to tell which of the dozens of different Inseego devices you own.
