favemuppet
Mar 13, 2021Aspirant
EX6120 Extender WPS LIght
Can someone give me an affirmative answer please as I have seen many conflicting.... Once my EX6120 extender has been connected to my Sky Router (set up via web browser), should the WPS light be so...
favemuppet
Thanks for taking the time to reply.
Conflicting views are techies on a Facebook group (yes I know what you are going to say) saying that the WPS light should only ever be blinking when connecting, and never on afterwards, and also posts on this forum saying the same thing - compared to various YouTube videos showing set up and implying it should always be on.
I have indeed RTFM (the full one, not the quick setup one), and it also implies that the WPS light should be solid green after connecting. It is silent about whether it should go off a short while after.
The behaviour I have seen is that it blinks during the connection process, but NEVER goes solid.
I tried an EX3700 before I got the EX6120 and this behaved exactly the same way. I sent it back as faulty.
antinode
Mar 13, 2021Guru
> are going to say) [...]
What I'd say say is that even if you had supplied helpful links to
any of that stuff, I likely wouldn't put much time+effort into reading
stuff on Facebook, and I'd rather rub sand into my eyes than watch a
typical "technical" movie on YouTube. "implying"?
But the connection succeeds?
Defects in Netgear documentation and/or firmware are not especially
unusual, sad to say.
- favemuppetMar 13, 2021AspirantSo are you saying that the fact that the WPS light is off doesn’t matter? That as long as I need a password to link a device to the extender, it will have the same security settings as the router?
If so, please link your source for confirmation of that.
Surely If defects in Netgear documentation and firmware is not unusual, does that not point to the fact the brand is unreliable? In which case, why should I spend my money on their equipment?- antinodeMar 13, 2021Guru
> So are you saying that the fact that the WPS light is off doesn't
> matter? [...]That's my belief. The whole idea of WPS is to allow a user to make a
wireless connection, even if he can't (or prefers not to) supply the
passphrase, _if_ he has control over the router. That is, if he can
press the WPS button (or provide a PIN).https://en.wikipedia.org/wiki/Wi-Fi_Protected_Setup
> [...] That as long as I need a password to link a device to the
> extender, it will have the same security settings as the router?Define "the same security settings". As I read the User Manual, you
should be able to play with the extender's SSID(s) and passphrase(s).> If so, please link your source for confirmation of that.
Why trust me (or Netgear, or anyone/anything)? I'd run the
experiment. Can you get a WPS-reliant client device connected without
pressing the WPS button? Can you get a non-WPS-using client device
connected without supplying the proper passphrase?> Surely If defects in Netgear documentation and firmware is not
> [...]You can rely on their imperfection.
> [...] In which case, why should I spend my money on their equipment?
Hey. It wasn't my idea. If you can find a better combination of
attributes elsewhere, then I'd use the Ayn Rand criterion, and get the
best thing (in my judgement) which I could find/afford to maximize my
happiness.- favemuppetMar 14, 2021Aspirant
Thank you for your time on this. Apologies if I appear thick but I am simply trying to understand,
press the WPS button (or provide a PIN).OK. You say it is your "belief", which is not the same as it being factual, Your belief may well be wrong. And I was after the facts.
should be able to play with the extender's SSID(s) and passphrase(s).The router is set up for WPA2-PSK(AES). If I connect a device, I am comforted in the knowledge that whatever I do with that device can not be seen by the outside world, and also that an outsider cannot join my network without a password etc...
When i connect an extender to that router, does the extender now have the same WPA2-PSK(AES) security settings as the router to which it is linked, and thus, when I connect a device to it I can be equally as comfortable? This is important because the user manual states (and this is the crux of my problem), that if the WPS light on the extender is off this means, and I quote, "WIFI SECURITY IS NOT ENABLED". That says to me, unless I am mistaken, that an outsider can potentially join my network easier via the extender, than they could via the router.
It is that phrase "WI-FI SECURITY IS NOT ENABLED" which concerns me,
connected without supplying the proper passphrase?The only devices I have with a WPS button are the router and the extender. I don't have a PC, only mobiles and tablets, All need a password to connect to the router and extender.
