johnb8
Mar 22, 2020Aspirant
EX6120 not working
Hi all. It seems mt EX6120 is died, no lights at all even using on/off button does nothing. Thought it would last longer, only purchased via Amazon mid December last year. Does anyone have the proc...
- Mar 22, 2020
click mynetgear at the top. Register an account and then the device. From there it'll show you if your device is still within warranty/support time period.
Mar 22, 2020Guru - Experienced User
- johnb8Mar 22, 2020Aspirant
Hi , Thanks for response. As suggested, l checked and it shows my extender with Hardware support until 11/12/21.
So l guess after looking further into it l have to obtain an RMA - what fun.
Also embarassed about the two bad typo's on original message!
Thanks again
Johnb
- michaelkenwardMar 23, 2020Guru - Experienced User
Did you check that it isn't just the power adapter that has gone bad?
If you have something similar lying around – check the volts and amps – you could try that.
These are generic devices. MIght be cheaper to buy a replacement than faff around with returns.
