jakechester97b's avatar
May 01, 2021
EX6120
I haved paired it with my router but my password from my router wont work on it?
1 Reply
  • plemans's avatar
    What router do you have?
    did you install it using wps?
    If so, factory reset the extender and reinstall it using the installation assistant and NOT wps.
    Wps can get coded different between manufacturers (it shouldn't)
