Philcoms
Apr 26, 2021Initiate
EX6130 répéteur wifi
Bonjour,
Après une tentative de mise à jour du firmware de mon EX6130, il m'est impossible de rédémarrer le répéteur et le reset usine ne fonctionne pas (même après 1 mn d'appui sur le bouton).
Merci de votre aide
Phil
Is the power light on and blinking?
If so you might have corrupt firmware.
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
- PhilcomsInitiate
Thanks for your reply, I'll try
Regards
Phil
