Blackrain2k
Jun 08, 2021Tutor
EX6150 5ghz drop
Hi everybody i have used my EX6150 with 2.4ghz for years without any problem. Now that i bought a modem/router that supports 5ghz I tried to configure the extender to use such bandwith. The extender...
- Jun 14, 2021
just to let you know that I have probably found the solution:
I have changed the wifi channel from my router and now i am no experiencing any drops in the connectionhope that this can be helpfull to others
Jun 08, 2021Guru - Experienced User
What router are you connecting it to?
Are you setting it up using wps or using the installation assistant?
- Blackrain2kJun 08, 2021Tutor
Hi Plemans, thank you for your quick reply!
I am using the router provided by my carrier:
Technicolor MediaAccess DGA4131FWBand setting it up with the installation assistant
Andrea
- plemansJun 08, 2021Guru - Experienced User
I couldn't find much info on that router (never a good sign)
A couple things you can try.
1. update the firmware on that extender. Looks a couple behind
2. setup the extender with a static ip address in your router
thank you Plemans
Yeah I know is a crappy router but I am forced to use it (long story short: by contract I have to use their router)
I will try what you suggested, hope this can help and solve the issuethank you again for your help!
