Blackrain2k
Jun 08, 2021Tutor
EX6150 5ghz drop
Hi everybody i have used my EX6150 with 2.4ghz for years without any problem. Now that i bought a modem/router that supports 5ghz I tried to configure the extender to use such bandwith. The extender...
- Jun 14, 2021
just to let you know that I have probably found the solution:
I have changed the wifi channel from my router and now i am no experiencing any drops in the connectionhope that this can be helpfull to others
Blackrain2k
Jun 08, 2021Tutor
Hi Plemans, thank you for your quick reply!
I am using the router provided by my carrier:
Technicolor MediaAccess DGA4131FWB
and setting it up with the installation assistant
Andrea
Jun 08, 2021Guru - Experienced User
I couldn't find much info on that router (never a good sign)
A couple things you can try.
1. update the firmware on that extender. Looks a couple behind
2. setup the extender with a static ip address in your router
- Blackrain2kJun 08, 2021Tutor
thank you Plemans
Yeah I know is a crappy router but I am forced to use it (long story short: by contract I have to use their router)
I will try what you suggested, hope this can help and solve the issuethank you again for your help!
- plemansJun 08, 2021Guru - Experienced User
The EX6150 has an access point mode if you hardwire it into the router.
Not sure the specs on your router but you could always see how that performs in comparision.
- Blackrain2kJun 14, 2021Tutor
