Blackrain2k
Jun 08, 2021Tutor
EX6150 5ghz drop
Hi everybody i have used my EX6150 with 2.4ghz for years without any problem. Now that i bought a modem/router that supports 5ghz I tried to configure the extender to use such bandwith. The extender...
- Jun 14, 2021
just to let you know that I have probably found the solution:
I have changed the wifi channel from my router and now i am no experiencing any drops in the connectionhope that this can be helpfull to others
Jun 08, 2021Guru - Experienced User
The EX6150 has an access point mode if you hardwire it into the router.
Not sure the specs on your router but you could always see how that performs in comparision.
Blackrain2k
Jun 14, 2021Tutor
