glass-goddess
Dec 08, 2020Tutor
EX6150v2 - incorrect password
I just got a new modem from CenturyLink. Set it up ok. Gave it a new password. Re-booted the extender (EX6150v2) and that seems to be ok. BUT when I try to connect on my phone, it keeps telling me "i...
- Dec 09, 2020
You can change the centurylink's ssid and password to whatever you prefer.
you'd need to reinstall/change it on the extender and device after changing it though.
Dec 09, 2020Guru - Experienced User
What modem do you have?
I actually want you to connect the extender to the PC via the ethernet. disconnect the pc from the modem/router and just connect it to extender to set it up. Not using access point mode.
glass-goddess
Dec 09, 2020Tutor
Modem is a C1100T refurbished from CenturyLink. Just got it Monday. Started this mess soon after.
WOW!!!!! IT WORKED!!!!! The only thing I did wrong was that it asked for the Key# (or something like that) and I put in the long abcd... one that CenturyLink used for the modem (thinking I had to use that so it would be the same). And not thinking that this really had nothing to do with the modem, I am now stuck with a really long PW, unless it's easy to change. But not worried about that now because...
I have been able to connect my iPad and cell phone!!!!! (I'm assuming when I move the extender, it will still work.)
Will try my Ring connection now.
But, ooooh... thank you so much!!!!
Stay safe... glass-goddess
- plemansDec 09, 2020Guru - Experienced User
