chandansikdar
Jan 01, 2020Initiate
EX6150v2 setup
As my wifi router has changed, I have done a factory reset of the extender EX6150v2 in order to set it up again. I am able to connect to NETGEAR_EXT. However when I click on the New Extender Setup i...
- Jan 01, 2020
I usually prefer to set these up with a hardwired connection to them if possible. it tends to go faster/smoother.
Have you tried the setup using a different computer or browser? Sometimes thats the issue
there's also the potential of setting up via wps. Have you tried that option?
Here's the support site with video guides, the install guides, the manual, and firmware.
Jan 01, 2020Guru - Experienced User
chandansikdar
Thanks plemans for your advice. I could get it by changing the browser from Chrome to Explorer. Now I have set it up right.
Regards
Chandan
- plemansJan 01, 2020Guru - Experienced User
Glad to hear you got it working! let us know if you have more issues and we'll be happy to help
