BlakeV
Jun 05, 2021Follower
EX6400v2 - tried to update firm ware- now not working
I tried to update firmware thru the app and it stalled then it said failed. It then turned off and only blinks green. I have tried to force the firmware but no dice. is there anyway to exchange this ...
michaelkenward
Jun 06, 2021Guru - Experienced User
Try these:
How to update firmware on your NETGEAR product | Answer | NETGEAR Support
And
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
