jzbedoya
Sep 10, 2022Follower
Express VPN on Nighthawk R6400 v2
How can I install the Express VPN firmware directly on my Nighthawk R6400 v2 router? Their instruction say to go to the admin panel but I can't access that on the Nighthawk app and Chrome says the IP...
michaelkenward
Sep 11, 2022Guru - Experienced User
In addition to the advice from plemans, try this:
Search - NETGEAR Communities – Express VPN
It may add to whatever you get from Express VPN, the best place to ask about how you use its system.
