Schmoozer
Feb 06, 2021Tutor
EXT3700 Acess Point speed issue
I am using mine as an access point. My wifi cable modem doesn't reach the basement well. I have a small home and I'm using this extender as an access point (not repeater). I ran a 50 ft cat6 cab...
Feb 06, 2021Guru - Experienced User
Because the EX3700 only has a 10/100mbps port and not gigabit?
Schmoozer
Feb 06, 2021Tutor
Didnt realize that...so why would it say it supports 433? Its supposed to support 433 as a repeater? I get like 25 mbps in repeater mode
- plemansFeb 06, 2021Guru - Experienced User
Repeater mode is even worse.
Reason why is extenders have to go router----extender and then extender-----device using the same chip. And it can't do both at once. so in repeater mode, its throughput is actually half of what its getting from the router.
And the numbers for wireless are always overblown.
I'd take a read of this to see what I mean.
Understand Wi-Fi 4/5/6/6E (802.11 n/ac/ax) (duckware.com)
- SchmoozerFeb 06, 2021TutorWell I feel like an idiot for missing the 10/100 but thanks for the info.
