Maril
Nov 25, 2020Aspirant
EXT7000 no internet
I have been using the EXT7000 for a year and the past few days I can connect but without internet. I have completed the reset with no luck. Any suggestions what should I look for?
Maril
Nov 26, 2020Aspirant
Hello, thank you for your reply. I'm connected to a virgin media hub 3.0 router and I am using the installation assistant.
michaelkenward
Nov 26, 2020Guru - Experienced User
What do the LEDs on the device look like?
Is it wired to the virgin media hub 3.0 router? Or is it a wifi link?
plemans also asked you about the firmware on your device.
I assume that you have the EX7000. Visit the support pages:
Support | NETGEAR
and feed in the actual model number and check the documentation for your hardware.
Check the troubleshooting section in the manual.
You may have done this already, but I can't tell from your message.
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
WiFi Range Extenders & Nighthawk Mesh - NETGEAR Communities
