BallyQ
Sep 09, 2021Aspirant
Extender doesn't work with Router after installing VPN
The WiFi range extender stopped detecting the router after I installed VPN on my ASUS RT-AC68U router. The pc uses Windows 10 and the devices attempting to receive the extended signal are Apple and ...
BallyQ
The extender' led for power and WPS/Mode are solid and green
The Router and Device lights are off.
I have not reinstalled the Extender. When I attempted to get to the Netgear page after typing xxxxxx and then selecting xxx to log into the extender, I received a message on a new tab "This site cannot be reached". Where xxxxx is the login URL.
I had to reset the router back to factory settings to get the VPN installed.
I can't remember how I installed the extender, except to say that once the cable was connected from the router to the plug socket it seemed to work pretty well.
Sep 09, 2021Guru - Experienced User
Factory reset the extender and install it using the installation assistant.
Push and hold reset for 7-15 seconds while its powered on.
then follow the installation assistant guide.
